verilog code of rom that is to be implemented into fpga
jhunjhun
Member level 1
shilong
send me verilog code of rom thhat can be implemented on fpga.
Taken from a Xilinx document. Most synthesis engines will infer RAM/ROM usage. You can, of course set the address and data widths to suit
// ROMs Using Block RAM Resources.
// Verilog code for a ROM with registered output (template 1)
// Download: **broken link removed**
// File: HDL_Coding_Techniques/rams/rams_21a.v
module v_rams_21a (clk, en, addr, data);
input clk;
input en;
input [5:0] addr;
output reg [19:0] data;
always @(posedge clk) begin
if (en)
case(addr)
6’b000000: data <= 20’h0200A; 6’b100000: data <= 20’h02222;
6’b000001: data <= 20’h00300; 6’b100001: data <= 20’h04001;
6’b000010: data <= 20’h08101; 6’b100010: data <= 20’h00342;
6’b000011: data <= 20’h04000; 6’b100011: data <= 20’h0232B;
6’b000100: data <= 20’h08601; 6’b100100: data <= 20’h00900;
6’b000101: data <= 20’h0233A; 6’b100101: data <= 20’h00302;
6’b000110: data <= 20’h00300; 6’b100110: data <= 20’h00102;
6’b000111: data <= 20’h08602; 6’b100111: data <= 20’h04002;
6’b001000: data <= 20’h02310; 6’b101000: data <= 20’h00900;
6’b001001: data <= 20’h0203B; 6’b101001: data <= 20’h08201;
6’b001010: data <= 20’h08300; 6’b101010: data <= 20’h02023;
6’b001011: data <= 20’h04002; 6’b101011: data <= 20’h00303;
6’b001100: data <= 20’h08201; 6’b101100: data <= 20’h02433;
6’b001101: data <= 20’h00500; 6’b101101: data <= 20’h00301;
6’b001110: data <= 20’h04001; 6’b101110: data <= 20’h04004;
6’b001111: data <= 20’h02500; 6’b101111: data <= 20’h00301;
6’b010000: data <= 20’h00340; 6’b110000: data <= 20’h00102;
6’b010001: data <= 20’h00241; 6’b110001: data <= 20’h02137;
6’b010010: data <= 20’h04002; 6’b110010: data <= 20’h02036;
6’b010011: data <= 20’h08300; 6’b110011: data <= 20’h00301;
6’b010100: data <= 20’h08201; 6’b110100: data <= 20’h00102;
6’b010101: data <= 20’h00500; 6’b110101: data <= 20’h02237;
6’b010110: data <= 20’h08101; 6’b110110: data <= 20’h04004;
6’b010111: data <= 20’h00602; 6’b110111: data <= 20’h00304;
6’b011000: data <= 20’h04003; 6’b111000: data <= 20’h04040;
6’b011001: data <= 20’h0241E; 6’b111001: data <= 20’h02500;
6’b011010: data <= 20’h00301; 6’b111010: data <= 20’h02500;
6’b011011: data <= 20’h00102; 6’b111011: data <= 20’h02500;
6’b011100: data <= 20’h02122; 6’b111100: data <= 20’h0030D;
6’b011101: data <= 20’h02021; 6’b111101: data <= 20’h02341;
6’b011110: data <= 20’h00301; 6’b111110: data <= 20’h08201;
6’b011111: data <= 20’h00102; 6’b111111: data <= 20’h0400D;
endcase
end
endmodule
thanks...........
but there is 8 bit address bus and 8 bit data bus and control signals like clock,reset,cipselect and wr/rd. i want to use spartan 3E fpga rom so how i use this rom and what code should write.
You can drive the enable with chipselect or the wr/rd signal and ignore the other one or you could gate together the two in the module in which this is instantiated eg
v_rams_21a my_instance_name(
.clk(some_clock),
.en(chipselect & rd), //depends on polarity of control signals you could use ".en(chipselect == 1 & wr/rd == 1)," then all you need to do is change the one to a zero if necessary
addr(address),
data(data_bus));
Change the address and data widths to 8 [7 : 0] on the module declaration and the case statement will start :
case(addr)
8'h00: data<= 8'h01; //or whatever value you need
8'h01: data<= 8'h02; //or whatever value you need
etc
endcase
you need the clock so that the synthesis engine will correctly interpret this as a ROM and you will find that this is correctly implemented in block ram.
