xman52
Xilinx ISE 10.1 Warning
Hello
Can anyone help me to solve the following issue?!
Actually, i wrote the verilog code for y cpu datapath. But while synthesizing its showing around 432 warning which is of same kind!!.
The warning that a getting is
RNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/MemWrite> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/RegDst> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/alu_src> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/RegWrite> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/alu_opcode_2> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/alu_opcode_1> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/alu_opcode_0> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/reg_25_21_4> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/reg_25_21_3> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/reg_25_21_2> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/reg_25_21_1> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/reg_25_21_0> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/reg_20_16_4> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/reg_20_16_3> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/reg_20_16_2> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/reg_20_16_1> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/reg_15_11_1> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/reg_15_11_2> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/reg_15_11_3> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/reg_15_11_4> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <r/reg_20_16_0> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <al/of_Mem_20_16_2> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <al/of_Mem_20_16_1> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <al/of_Mem_20_16_0> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <al/ex_RegWrite> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <al/ex_MemToReg> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <al/ex_MemWrite> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <al/ex_MemRead> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <al/of_Mem_20_16_3> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <al/of_Mem_20_16_4> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <d/d_dst_0> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <d/d_dst_1> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <d/d_dst_2> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <d/d_dst_3> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <d/d_dst_4> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <d/d_RegWrite> (without init value) has a constant value of 0 in block <datapath>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:2677 - Node <r/branch> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_31> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_30> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_29> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_28> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_27> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_26> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_25> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_24> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_23> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_22> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_21> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_20> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_19> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_18> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_17> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_16> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_15> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_14> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_13> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_12> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_11> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_10> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_9> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_8> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_7> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_6> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_5> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_4> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_3> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_2> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_1> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <r/reg_pc_0> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <d/dmem_written> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_31> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_30> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_29> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_28> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_27> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_26> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_25> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_24> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_23> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_22> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_21> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_20> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_19> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_18> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_17> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_16> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_15> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_14> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_13> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_12> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_11> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_10> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_9> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_8> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_7> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_6> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_5> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_4> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_3> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_2> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_1> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/branch_address_0> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <al/ex_pc_src> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <i/count_0> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <i/count_1> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <i/count_2> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <i/count_3> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <i/count_4> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <i/count_5> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <i/count_6> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <i/count_7> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <i/count_8> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <i/count_9> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <i/count_10> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <i/count_11> of sequential type is unconnected in block <datapath>.
WARNING:Xst:2677 - Node <i/count_12> of sequential type is unconnected in block <datapath>.
What i came to see in some blogs is that this is trimming done as to optimize the block.!! But what am seeing from the code is that the warning of the above kind is even coming when am assigning my signal to zero at reset!!
What to do now!!?
Hello
What to do now!!?
