farhanashirin
Junior Member level 1
I faced some these following problems,anybody can help me?
1.Write a verilog description for the following function.
f(A,B,C,D)=Σm(0,2,4,5,6,7,9,10,11), d(1,13)
2.Show verilog code for a cascadable 4 to 2 priority encoder.Your circuit should have an enable input,four data inputs,an enable output,an interrupt output,and two source id outputs.All input and outputs must be active high.for cascading purposes and to be able to use wired -OR logic,use tri-state for ur id outputs.Adjust the details of your design for a better cascading capability.
thanks in advance.\][/url][/code]
