verilog code confusion
yann_sun
Member level 1
Hi, all
My question is why neg_A and neg_B are unequal.
To be specific, neg_A derives from the last negative edge of A, however, neg_B is the present negative edge of B.
Stimulus A and B are the same.
Here is the code
always @(A) begin
if(A) pos_A=$realtime;
else neg_A=$realtime;
end
always @(negedge B) begin
neg_B=$realtime;
$display("%f",neg_A);
$display("%f",neg_B);
end
I think the reson is that the always blocks execution sequence is not defined by IEEE standart, so simulator can evaluate first always @(A) block and after always @(negedge B) or vice-versa.
If always @(negedge B) will be evaluated first you will see the new value for neg_B and the old one (from the previous neg A event) for neg_A...
Read more about event shedule during the simulation process here.
Thanks Alosevskoy,
What do you mean by if?
Is it evaluated randomly?
Does it depend on different simulator?
---------- Post added at 02:50 ---------- Previous post was at 02:49 ----------
Thanks Alosevskoy,
Yes, as I understand different simulator may create different event sequences in which always blocks are evaluated, so the results are different )
What the simulator do you use? I tried to model following code and neg_A and neg_B were the same (simulator ISim from Xilinx ISE)...
module tb(
realtime pos_A, neg_A, neg_B;
reg tgl_Ev = 0;
always #(10) tgl_Ev = ~tgl_Ev;
always @(tgl_Ev) begin
   if(tgl_Ev) pos_A=$realtime;
end
always @(negedge tgl_Ev) begin
   neg_B=$realtime;
   $display("----------------------");
end
initial
   #(100) $finish;
endmodule
I've just tried to model this code with free Icarus Verilog (iverilog) simulator and it gave me a different result:
0.000000
20.000000
20.000000
40.000000
40.000000
60.000000
60.000000
80.000000
The results from ISim and ModelSim are the same:
20.000000
20.000000
40.000000
40.000000
60.000000
60.000000
80.000000
80.000000
I'm using vcs.
Vcs got the same result as iverilog by simulating your tb code.
