thank you very much for replying.I am posting my code which I took from somewhere and modified it....
module add(
input wire signl, sign2,
input wire [3] expl, exp2,
input wire [7] fracl, frac2,
output reg sign_out ,
output reg [3] exp_out ,
output reg [8] frac_out
// signal declaration
// suffix b,s,a,n for
// big ,small ,aligned , normalized number
reg signb,signs;
reg [3] expb,exps,expn,exp_diff;
reg [7] fracb,fracs,fraca,fracn,sum_norm ;
reg [8] sum;
// body
always @*
begin
// 1st stage : sort to find the larger number
if ( {expl,fracl} > {exp2,frac2})
begin
signb=signl;
signs=sign2;
expb=expl;
exps = exp2;
fracb=fracl;
fracs=frac2;
end
else
begin
signb=sign2 ;
signs=signl;
expb =exp2 ;
exps =expl ;
fracb =frac2 ;
fracs =fracl ;
end
// 2nd stage : align smaller number
exp_diff= expb - exps ;
fraca=fracs >> exp_diff ;
// 3rd stage : add / substract
if(signb == signs )
sum ={1'b0 ,fracb}+{1'b0,fraca} ;
else
sum={1'b0,fracb}-{1'b0,fraca};
// form output
sign_out = signb ;
exp_out = expb ;
frac_out =sum;
end
endmodule
Added after 1 minutes:
and for the 2nd problem that was assigning the pin. I am using nexys two board n I think there are only 8 switches through which I can give input. But in this code you can see that I need two input of 13 bits wide. So how can I do that ? thnx in advance..
