[SOLVED] verilog and vhdl in same project, problems
punj33
Newbie level 6
As a part of my project, I need to interface with DDR SDRAM and I have an IP core of RAM controller. However, my whole project is in Verilog and the ip i got is in VHDL.
So, can a project have both VHDL and Verilog ?
I saw in the forums and learnt about XHDL. How efficient is it? I tried to convert one of the files of the controller but the demo refused to convert citing the file is too large. Are there any free sources or any other alternatives ?
You can mix VHDL and Verilog if your simulator and synthesizer supports both languages (is sometimes an add-on feature).
In your Verilog code instantiate your VHDL ip-core just like if it was a Verilog module.
Devas
Reactions: punj33
    punj33
thank you. I am using Xilinx 10.1 and i reckon it should support .
It means i dont need any thing like XHDL, isn't it. Thats a relief
When your simulator/synthesizer has mixed language support there is no need for XHDL.
Devas
I tried a simple program where I instantiated vhdl from my verilog code
library ieee;
use ieee.std_logic_1164.all;
entity mainvhdl_en is
port (in1,in2:in std_logic;
out1,out2:eek:ut std_logic);
end entity;
architecture mainvhdl_arch of mainvhdl_en is
begin
out1<=in1 or in2;
out2<=in1 and in2;
end architecture;
module test1(a,b,c,d);
input a,b;
output reg c,d;
mainvhdl_en mainvhdl_en1(.in1(a),.in2(b),.out1(c),.out2(d));
endmodule
Then the error I get in modelsim when i try to simulate the verilog module is :
# ** Fatal: (vsim-3364) Illegal Verilog connection (3rd) for VHDL output port 'out1'.
# Time: 0 ns Iteration: 0 Instance: /test1/mainvhdl_en1 File: vh.vhd Line: 6
# FATAL ERROR while loading design
# Error loading design
do I have to change some settings in modelsim like mixed language sth ?
When mixing VHDL and Verilog design entities, you have to keep the syntax rules of both languages.
Your example is using illegal Verilog syntax in the module instantiation, the problem hasn't to do with VHDL or Verilog module. You simply can't connect a variable of the reg type with a module output port. It has to be a wire.
