willshan02
Newbie
I am trying to write Verilog-A for a 5-bit SAR ADC which will act as a circuit block that controls the logic for the SAR algorithm and will output signals that control the switching on each capacitor. Here is what I have so far, I am getting syntax errors near the end with converting sar_out_int to a real variable so that I can map it to sar_out. Any ideas?
`default_transition 1n
module SARLOGIC (
clk,
start,
comp,
sar_out,
switch_ctrl0,
switch_ctrl1,
switch_ctrl2,
switch_ctrl3,
switch_ctrl4,
done
input clk;
input start;
input comp;
output sar_out;
output switch_ctrl0;
output switch_ctrl1;
output switch_ctrl2;
output switch_ctrl3;
output switch_ctrl4;
output done;
integer sar_out_int;
real sar_out_real;
integer trial_code;
integer bit_pos;
integer done_int;
analog begin
@(initial_step) begin
sar_out_int = 0;
trial_code = 32;
bit_pos = 5;
done_int = 0;
end
@(cross($abstime - 0.5, 1)) begin
if (start) begin
sar_out_int = 0;
trial_code = 32;
bit_pos = 5;
done_int = 0;
end else if (done_int == 0) begin
if (comp)
sar_out_int = sar_out_int | trial_code;
trial_code = trial_code >> 1;
bit_pos = bit_pos - 1;
if (bit_pos == 0)
done_int = 1;
end
end
// Assign outputs using contribution operator
sar_out_real = $itor(sar_out_int);
sar_out <+ $itor(sar_out_int);
switch_ctrl0 <+ (trial_code & 1);
switch_ctrl1 <+ ((trial_code >> 1) & 1);
switch_ctrl2 <+ ((trial_code >> 2) & 1);
switch_ctrl3 <+ ((trial_code >> 3) & 1);
switch_ctrl4 <+ ((trial_code >> 4) & 1);
done <+ done_int;
end
endmodule
