Verilog-A Error & PSS analysis
AMSA84
Advanced Member level 2
Iberian Peninsula
Hi guys,
I wrote a small code from a Verilog A tutorial for a comparator.
After implement it, I tried to simulate a simple circuit - Vpulse shaping a triangle wave and a vdc source to see what would appear at the output.
I used a PSS analysis and an error appeared:
It says that PSS doesn't support behavioral models with hidden states. Is that true? There is any way to escape from this error and use PSS analysis?
What is hidden states?
Hidden states are possible circuit states which are not planned to occur in the circuit's special application.
A nice example is a decimal counter made from 4 flip-flops: it could get into 16 states, but just 10 of them are used. If by any event, e.g. a power supply interference or a radiation SEE the circuit falls into such an unplanned (hidden) state, the circuit itself should care to leave it, e.g. by a reset.
Also, a single flip-flop, even a comparator could fall into such a hidden state by such an unplanned event.
