Verilog-a code to latch analog voltages
Chinmaye
Full Member level 3
Dear all,
I am trying to model analog latch in verilog-a but have been unable to do it. The requirement is as follows
It is required to sample an analog value at positive clock cycle of CLK2 and hold the same value even during the negative clock cycle of CLK2.
Any leads??
Chinmaye
Full Member level 3
@cross() does not allow V() inside it. Hence it cannot be used
pancho_hideboo
Advanced Member level 5
Real Homeless
No.
You can not understand Verilog-A at all.
if V(clk2) >=0 aho = V(in);
@cross(V(clk2), -1) aho = V(in);
V(out) <+ aho;
vivekroy
Full Member level 5
UK
Dear all,
Any leads??
Look at page 113 of **broken link removed**
Your exact solution is given!!
pancho_hideboo
Real Homeless
This is not transparent latch.
For V(Clk2)=High, V(out)=V(in) ; Tranparent
Then V(in) is captured at negative edge of V(Clk2).
V(out) is constant during V(Clk2)=Low ; Hold Mode.
vivekroy
Full Member level 5
UK
Here you go
// VerilogA code
`include "constants.vams"
`include "disciplines.vams"
module veriloga_latch(vin,vclk,vout_sampled);
input vin,vclk;
output vout_sampled;
voltage vin, vclk, vout_sampled;
parameter real vdd=1;
real vsample=0;
analog begin
	if (V(vclk)>0.9*vdd) begin
		vsample=V(vin);
	end
	V(vout_sampled) <+ vsample;
	end
endmodule
Here is the op:
