Register Log in
Verilog-a code for differential amplifier
Chinmaye
Hello all,
Here is a simple verilog-a code for an amplifier with differential input and differential output. This works fine with resistors but if i try to use it with switched capacitor circuit, it gives an error
ERROR (SPECTRE-16384): Signal I(I31.V1:p) = 1.07846 GA exceeds the blowup limit for the quantity `I' which is (1 GA). It is likely that the circuit is unstable.
Please let me know what modifications needs to be done to correct it.
module simple_opamp_t(sigin_p, sigin_n, sigout_n, sigout_p);
input sigin_p, sigin_n;
output sigout_p, sigout_n;
electrical sigin_p, sigin_n, sigout_p, sigout_n;
parameter real gain = 1000000;
parameter real sigin_offset = 0;
   analog begin
      V(sigout_n) <+ (V(sigin_n) - sigin_offset) * gain;
	  V(sigout_p) <+ (V(sigin_p) - sigin_offset) * gain;
end
endmodule
pancho_hideboo
Advanced Member level 5
Real Homeless
What switch do you use in switched capacitor circuit ?
Is it MOSFET or behavioral ideal switch ?
pancho_hideboo
Real Homeless
Your code is not differential amplifier.
analog begin
  vdiff = V(sigin_p) - V(sigin_n);
  V(sigout_p) <+ vdiff * gain / 2 + vcom
  V(sigout_n) <+ -vdiff * gain /2 + vcom
end
endmodule
Chinmaye
Thank you. Shall try this.
Toggle Sidebar
Design Fast
