Verification methodology of motion estimation in H.264/AVC
win3y
Member level 1
Hi;
I am currently doing Motion estimation (ME) in H.264/AVC. My question is about verification methodology of motion estimation in H.264/AVC. Who has some experiences in this please help me? Could anyone interested in discuss together?
Any suggestion is welcome. Many thanks
Win3Y
Re: Verification methodology of motion estimation in H.264/A
Hi
Let me know which HDL u are using?
whether u written full RTL code for ME?
research_vlsi said:
Hi
I used Verilog for RTL code. Motion estimation that I coded includes two parts: integer ME almost similar to JM reference software, and the other is fractional ME with new algorithm. However I want to make sure that RTL code with its functionality working correctly.
Thank for replying.
Win3Y
well as u said u use JM reference C code, give your testing bit stream to C reference code, extract the results to a text file. same you do that for HDL. compare the two files.
so that C generated result and HDL result will match if coded correctly.
use gvim editor for comparing.
Thank you for your answer.
I hope this way is good enough for verification, even it is quite difficult.
Win2Y
