Verdi waveform viewer fsdb file path
ashanmu2
Newbie level 2
Hi All,
i sometimes open multiple verdi waveforms to comapre against different simulations. is there a way to view the full path of the fsdb being currently loaded in a waveform window? I tried reading it form the top of the waveform dialog box, but it always "..." out most part of the full path .
Thanks in advance!
swabhi812
Member level 2
Hi All,
Thanks in advance!
I am not sure if you are still looking for an answer for this question as it is an old post. However, from nWave window if you click on File->Open, it will show you the last path from where it loaded FSDB.
Thanks.
ashanmu2
Newbie level 2
Thank you very much for your reply. I had tried that method, but the problem occurs when i have opened multiple waves, and the file->open always points to the last path instead of the path of current window.
Eg:
I have wave window1 which loaded the fsdb1 from path dir1/fsdb1,
and in that window , I did tools->new window and opened another window2.
In window2 , i loaded fsdb2 from dir2/path2 .
both the waveforms' File->Open now points to the window that i opened last which is dir2/fsdb2. Because of this I am unable to find which window is from which path.
Recently , I have started doing Windows->Dock to New container . I name this containers for each window to help me find the relevant dir of the fsdb.
