vendor parts simulation error in ADS
longlongago0715
Hi experts,
I'm facing this weird probem when running an S parameter simulation using coilcraft inductor library, what's the probem here?
I guess this is a compatibility problem and I think you created manually that symbol by attribute associated s-parameters. I believe you did a mistake while creating.
I use generally transmission line equivalent circuit model for inductors because this model is compatible with all frequencies and not discrete data based.
Thanks for you reply BigBoss, what do u mean created manually the symbol? I just follow the Coilcraft website instruction to unzip the design kit, and i didn't do anything else to modify it. It's the same way as other design kits installation like Murata library.
by the way ,could you tell me more about using transmission line equivalent circuit model for inductors, how to do that?
Read for your part.
LaTeX Commands Quick-Menu:
