Vehicle Sensor - how to design it?
ASIC
Full Member level 3
Full Member level 3
Vehicle Sensor
I need to design a car sensor to be places in the ground under the road for detecting the precense of cars. The system must be static, i.e. I can power down the sensors, and when powered up again, I can check if there is a car there or not. Any design ideas?
ASIC
I am not an expert in this stuff at all, but what I would do is to see variations of the conventional magnetics principles. One interesting article is http://www.itsa.org/subject.nsf/Files/3116/$file/3116.pdf
Good luck,
Ted
Hi asic
I see two possibilities:
1) A car is made with a lot of metal. If you use a big inductor built under
the car and use this inductor to build an oscillator you can see a drastic
frequency-change if a car is placed above the inductor
2) You use a radar or ultrasonic distance-sensor. If no car is present, you
will see (perhaps) an object in a distance over 2 meters (your roof). If
a car is present, this distance goes down to about 0.4meters
Greets
