Vdc opamp feedback amplifier transfer function
yefj
Advanced Member level 1
Hello,there is a circuit i saw which is supposed to amplify a DC signal input,in the circuit bellow its called Vdc as shown bellow.
I can see there is a feedback,In AC we have virtual ground and we do equation of currents.but here we have DC only input.
how do we calculate the Vout from Vdc and Va?
Thanks.
KlausST
Super Moderator
Staff member
"Virtual ground" is not for AC only. It's a function of a circuit. Mainly caused by an inverting Opamp circuit.
Your circuit is non inverting.
Every document or tutorial for "non inverting Opamp circuit" shows how to calculate gain and output voltage.
It's all standard.
Klaus
yefj
Hello Klauss ,If i undersatand you correctly given the circuit bellow.
V_plus=V_minus
also the current of V_minus/R1 is the current flowing on the R4 loop
(Va-Vout)/R6+(Va-Vout)/R5 flows into R4
so V_minus=[(Va-Vout)/R6+(Va-Vout)/R5]*R1
V_minus=V_plus (virtual ground)
I am stuck at this step.
where did i go wrong developing the expression for Vout?
Thanks.
FvM
Super Moderator
Staff member
Bochum, Germany
The circuit has several useless components. R2 and R3 don't affect the output voltage, also R5 and R6 and the voltage at Va have no influence on Vout, at least if the output current capability of OPA495 isn't exceeded.
danadakk
Advanced Member level 3
Your circuit essentially, as previous posters point out, reduces to this -
If your load on the output is infinity then eliminate R5paraR6 as no current flows
thru it if load R is infinite.
Note the common mode input range of this opamp does not include V+, worst case
it has to be, in your circuit, < Vdd - ~ .8V.
If you want circuit to work up to Vdd then OpAmp has to have RR input.
Note ignore the opamp part number shown. My slip up in simulator. But comments above
apply to yours.
Regards, Dana.
KlausST
Super Moderator
Staff member
how to start analizing your circuit
This is a standard non inverting OPAMP circuit. Most basic. Thus it has been discussed maybe million times before.
V_DC --> V_plus
V_plus --> V_minus
V_minus --> V_R1
--> thus you can calculate I_R1
I_R2 = I_R1
--> thus you can calculate V_R2
--> thus you can calculate V_Out
Klaus
yefj
Hello Klauss, my OPAMP model is as shown bellow,LTspice is not allowing me to simulate its model so i used an alternative model just to simulate the principle,and see the transfer function in action.
I need to have this -3 Volts on the output side (its on the MAX 4231 original circuit) as shown bellow.
My circuit has two outputs
You said i should disregard R3 and R4 So V_plus=Vnon_inv=0.5v
So V_minus=0.5v also
so the current threw R1 is I_R1=0.5/R1 which is also the current that flows threw R2
0.5/R1=(Vout-0.5)/R2
Because R1=R2 Vout=1V which matches the simulation.
I=((1--3)/600)=1/150
Vout2=1-500*I=1-500*6.66*10^-3=-2.33V
which also matches to the simulation.
but in the the MAX4231 i also have the option of SHDN
So if i understand the data sheet bellow correctly when SHDN pin is 0V then the OPAMP output is GND and we have voltage divider between 0 and -3 instead of 1 and -3?
correct?
KlausST
Super Moderator
Staff member
Hi.
correct?
Yes.
Klaus
added:
Usually there is the recommendation to drive the ouput only within the supply rails.
But you try to pull it below it´s supply rail.
Now it depends on how the output stage is designed.
In worst case it can´t handle negative currents referenced to GND.
A FET output should be able to drive the current both directions. Not sure how the OPAMP reacts on this reverse current.
Klaus
Reactions: yefj
    yefj
FvM
Super Moderator
Staff member
Bochum, Germany
Not exactly. The output is disabled (high impedance). Negative output is limited to the forward voltage of substrate diode.
LaTeX Commands Quick-Menu:
