@Pra
Newbie
Am using VCO (POS-400+) to generate a fixed 300MHz signal.
This VCO output is connected to an Attenuator (ZX73-2500+ ) and the attenuator output is further fed to a RF Amplifier (ZHL-1-2W+) all with supporting electronics for controls.
This has been working fine. (all components are Mini-Circuits make)
Now, my application demands that: I use that same VCO output signal (300MHz) to feed to another attenuator (in parallel to the above) and another RF amp (ZHL-1-2W) is connected to the output of this second attenuator.
ISSUE:
While I am connecting in this mode, the output of the second RF amplifier is heavily dropping to ~10% of its normal expected output while the original RF amp drop is marginal. As I realized, this is due to the VCO output itself is dropping.
QUERY:
1) Is there an issue in the design ?
2) Any remedies/corrections recommended viz: matching issues?
3) What could be the reason for this drop in signal & how to correct it?
Please provide technical help or recommend suitable help centers/ websites.
Thanks.
ISSUE:
QUERY:
Thanks.
