vcc and ground inversed
freemanantony
Member level 4
Chennai, India
hai everyone
what will happen to a board if the supply voltage is given to ground and ground is given to supply pin?
prakashvenugopal
Advanced Member level 1
hi,
If you have a diode placed in the positive supply input, no damage. If you didnt, loading can occur.
scorrpeio
Full Member level 5
The track of PCB will be damaged if the power supply is DC battery.
If it is transformer and power regulator, either fuse or power regulator IC will blow of.
When power source is grounded directly, because source sees virtually no resistance, heavy current flows through the path damaging power source and/or path.
Can anyone put more light on this?
---------- Post added at 11:16 ---------- Previous post was at 11:15 ----------
I dont think there is any effect of connecting the ground of supply to +ve of the board.
raksha singh
Member level 4
mumbai
first of all clear, for which application you have got this query ????
if we see normally the condition you have given then there will be a "dead short".
