per_lube
I got a question regarding Microwave DRO (Dielectric Resonator Oscillator).
Could anyone explain how sensitive is the output frequency of a DRO with the dielectric resonator placement between coupling lines?
If the oscillator is set to work at 10 GHz, what will be the variation of output frequency with the resonator is displaced as follows...
1. if the resonator displaced about 0.1~0.2 mm away from the coupling line from the original position
2. if the resonator displaced about 0.1~0.2 mm closer to the coupling line from the original position
3. if the resonator is raised about 0.1~0.2 mm from the substrate
I don't have access to a DRO to do this experiment.
cheers,
per_lube
cheers,
per_lube
