Variables are not displaying on the LCD
ADGAN
Full Member level 5
Full Member level 5
Hi! I have written a code to display date and energy consumption for a project using MPLAB C18. Everything displays perfectly in Proteus but when I tested in real hardware variables such as date, time doesn't display on the LCD. I tried a MikroC example code and it displays everything perfectly. Can somebody explain me what I may have done wrong? I'll post some necessary parts of the code below.
#include <p18cxxx.h>
#include "LCD.h"
#include "LCD_Config.h"
//#pragma udata
union LCDv8bit LCD_data;         // bitfield variable (bitwise acess)
unsigned short LCD_busy_cnt;
// -------------------- LCD-functions ------------------------------------------
#ifdef LCD_ON
void LCD_On (void)
    LCD_ON = 1;
    LCD_ON_DIR = 0;
#warning DO NOT FORGET TO SWITCH ON THE DISPLAY AND TO ADD A POWER UP DELAY !
#endif
void LCD_Init (void)
    LCD_RW = 0; LCD_RW_DIR = 0;
    LCD_RS = 0; LCD_RS_DIR = 0;
    LCD_E  = 0; LCD_E_DIR  = 0;
    LCD_D4_OUT = 0; LCD_D4_DIR = 0;
    LCD_D5_OUT = 0; LCD_D5_DIR = 0;
    LCD_D6_OUT = 0; LCD_D6_DIR = 0;
    LCD_D7_OUT = 0; LCD_D7_DIR = 0;
    LCD_busy_cnt = 1;		// busy_flag time out counter
    LCD_DELAY_5MS();LCD_DELAY_5MS();LCD_DELAY_5MS();    // wait for 15ms
// display reset procedure
    LCD_Write_Nibble(LCD_RESET);    LCD_DELAY_5MS();
// set 4-bit mode always !!!
    LCD_Write_Nibble(FOUR_BIT);     while (LCD_Busy()) {;} // wait
#if defined EXT_LCD_3_3_V
    LCD_Command(FOUR_BIT_TWO_LINE + EXT_INSTR_TBL_1);
    LCD_Command(EXT1_BIAS_1_5);
    LCD_Command(EXT1_CONTRAST + 0x0C);
    LCD_Command(EXT1_BOOST_ICON_C + BOOST_ON + 1);
    LCD_Command(EXT1_FOLLOWER + FOLLOWER_ON + 5);
#elif defined EXT_LCD_5_V
    LCD_Command(EXT1_BIAS_1_4);
    LCD_Command(EXT1_CONTRAST + 0x04);
    LCD_Command(EXT1_BOOST_ICON_C + BOOST_OFF + 2);
    LCD_Command(EXT1_FOLLOWER + FOLLOWER_ON + 1);
#else
    LCD_Command(FOUR_BIT_TWO_LINE);
#endif
    LCD_Command(DISPLAY_CTRL + DISPLAY_ON);// + BLINK_ON);
    LCD_Command(ENTRY_MODE + CURSOR_INC + DSHIFT_OFF);
    LCD_Command(CLEAR_DISPLAY);
    LCD_Command(RETURN_HOME);
void LCD_signalsTest()
    LCD_RS_DIR = 0;
    LCD_RW_DIR = 0;
    LCD_E_DIR = 0;
    LCD_D4_DIR = 0;
    LCD_D5_DIR = 0;
    LCD_D6_DIR = 0;
    LCD_D7_DIR = 0;
    LCD_RS = 1;
    LCD_RW = 1;
    LCD_ENABLE();
    LCD_D4_OUT = 1;
    LCD_D5_OUT = 1;
    LCD_D6_OUT = 1;
    LCD_D7_OUT = 1;
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_DISABLE();
    LCD_D4_OUT = 0;
    LCD_D5_OUT = 0;
    LCD_D6_OUT = 0;
    LCD_D7_OUT = 0;
void LCD_Write_Nibble(unsigned char value)
    LCD_data.all = value;
    LCD_RS = LCD_CMD;
    LCD_RW = LCD_WR;
    LCD_D4_OUT = LCD_data.bit4;
    LCD_D5_OUT = LCD_data.bit5;
    LCD_D6_OUT = LCD_data.bit6;
    LCD_D7_OUT = LCD_data.bit7;
    LCD_STROBE();
void LCD_Write(unsigned char value) // command or data
    LCD_RW = LCD_WR;
    LCD_STROBE();
    LCD_D7_OUT = LCD_data.bit3;
    LCD_D6_OUT = LCD_data.bit2;
    LCD_D5_OUT = LCD_data.bit1;
    LCD_D4_OUT = LCD_data.bit0;
    LCD_STROBE();
void LCD_ConstTextOut(unsigned char row, unsigned char col, const char *text)
   unsigned char data;
   switch(row){
   case 0: data = ROW_0 + col; break;
   case 1: data = ROW_1 + col; break;
   case 2: data = ROW_2 + col; break;
   case 3: data = ROW_3 + col; break;
   default: break;}
    LCD_Command(CURSOR_ADDR + data);
    while (*text) {
        LCD_CharOut(*text++);
void LCD_TextOut(unsigned char row, unsigned char col, unsigned char text[])
   unsigned char data,i = 0;
   switch(row){
   default: break;}
    while (text[i]) {
    LCD_CharOut(text[i++]);
unsigned char LCD_Busy(void)
    if (LCD_busy_cnt >= LCD_TIMEOUT){
        LCD_busy_cnt = 1;
        return 0;                   // return -1 for time out ???????????????
    LCD_RW = LCD_RD;
    LCD_RS = LCD_CMD;
    LCD_D4_DIR = 1; LCD_D5_DIR = 1; LCD_D6_DIR = 1; LCD_D7_DIR = 1;
    LCD_ENABLE(); LCD_DELAY_1US();
    LCD_data.bit7 = LCD_D7_IN;
    LCD_DISABLE();
    LCD_data.bit3 = LCD_D7_IN;
    LCD_DISABLE();
    LCD_D4_DIR = 0; LCD_D5_DIR = 0; LCD_D6_DIR = 0; LCD_D7_DIR = 0;
    LCD_RW = LCD_WR;
    if (LCD_data.bit7 == LCD_BUSY) {
        LCD_busy_cnt++;
        return 1;
    } else {
        LCD_busy_cnt = 1;
        return 0;
// -------------------- END LCD-functions ---------------------------
For example to display date on the LCD:
tnum[0] = day1/10 + 48;
tnum[1] = day1%10 + 48;
tnum[2] = '\0';
LCD_TextOut(2,7,tnum);
To display the energy consumption:
ultoa(ENERGY_ACT,txt7);
LCD_TextOut(3,3,txt7);
Thanks for the reply. I tried it now but still it didn't work.
I'm using a 4MHz crystal with PLL enabled.
The original one was:
#define LCD_DELAY_5MS() Delay10KTCYx(1)
#define LCD_DELAY_1US() Nop(); Nop(); Nop(); Nop(); Nop();
I modified it to this:
#define LCD_DELAY_5MS() Delay10KTCYx(28)
#define LCD_DELAY_1US() Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop();Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop();Nop(); Nop(); Nop(); Nop(); Nop();Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop();Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop();Nop(); Nop(); Nop(); Nop(); Nop();
I really don't know how to calculate these delays.
I can't open the link. It says " Error: The requested page could not be found ".
Ok I found the pdf. But how do I know the TCY of my PIC? Is it 1/16us? I changed the delays assuming its 1/16us, but still it didn't work.
I even gave large delays, but still not working. I feel like something else is wrong.:-(
Hey Jayanth were you able to find the problem with my code?
I told you to include device header file in the source file. If you want me to compile and test then zip and post the whole project file. I don't have patience to create a new project just for testing.
I'm really sorry I thought you said to include it here
I tried it too but didn't work
  • AEBS.rar
