Register Log in
Variable voltage source generation using pic18f4520(5v and 30ma)
palakpatel6188
Newbie level 5
I need to provide 1V to 5V variable voltage to a device to control its operation. and we also want 30 mA.
I have triaed it using PWM and generated variable voltage but i didnt get the desired current.
I need to provide a up and down push button which should vary the output voltage from 1 volt to 5 volts.
What is the the practical method with common components? PWM possible? p.PNG
I can handle a PIC well. But hardware? If We use PWM how to smooth it using op-amp or something?
barry
Advanced Member level 5
California, USA
If you use PWM you'll need to use an RC filter. It depends on how much ripple you can tolerate. Some PICs have Digital-to-analog converters-you could use one of those. Or use an external DAC.
I just noticed, you actually ARE using a DAC. So, why are you talking about PWM?
amayilsamy
Advanced Member level 1
Chennai,India
You can simply do with using DAC. MCP4716 I2C based DAC 5 V output, 25 mA output..
horace1
Norwich, UK
Toggle Sidebar
Design Fast
