[AVR] Variable value convert in decimal
BHARGAVSHANKHALPARA
Junior Member level 3
GUJARAT INDIA
Hi all...
i am programming ATMEGA32 microcontroller and ATMEL STUDIO 6 for programming in my application.
in my application user enter 3 difference value which i have store in char variable.
At the end i combine this 3 value in one variable and compare it with predefine value. when i combine in one variable it automatically convert into decimal.
for example i have 3 variable named S1,S2,S3
user enter S1=2,S2=0,S3=9;
at end combine value in TOTAL variable which is INT.
TOTAL = (S3 | (S2 << 4) | (S1 << 8));
so TOTAL value should be 209
but it shows after decimal conversation 521.
when i compare it with 209 this gives no result, but it gives result when my predefine value 521.
i want to get result when user enter 209 and my predefine value also 209.
You seem to be assuming that 2<<8 is 200. In my calulation it's 512.
The C operator << is describing binary rather than BCD operation.
you can try thiis:
uint_16 a;
int b;
a = S3;
a = (a<<8)|S2;
a = (a<<8)|S1;
b = a ;
you can try this:
uint_16 a;
int b;
a = S3;
a = (a<<8)|S2;
a = (a<<8)|S1;
b = a ;
Did you understand at all what the original poster wants to achieve? It rather looks like he want to assemble decimal digits, like
TOTAL = (S3 + (S2 * 10) + (S1 * 100));
respectively performed as sequential action
TOTAL = (S1*10 + S2)*10 + S3;
