T
treez
Hello,
Please could you check the attached fan drive circuit for driving the "ebm papst 8218 JH3" fan? Please advise if this circuit is OK?
Basically, as you may see, it is driving the fan from a Buck converter.
Do you believe that the 10uF capacitor across the fan is enough capacitance?
The PWM is at a frequency of 100KHz, and its duty is variable by a microcontroller.
Please could you also supply the coil inductance of the fan?
Fan datasheet:
Fan series datasheet:
Fan datasheet:
