asimraufawan
Member level 2
Hi all,
I m reading current of 0-0.5 ampere from current transformer the construction of a current transformer is such that it sense current at primary side & give AC voltage 0-5 VAC at secondary side & i connect a bridge rectifier to convert it in DC volt. The problem is the DC voltage does not match in every circuit therefore i need to add a variable resistor.
The circuit is attached kindly help me out how will i add the potentiometer in the same circuit, to maintain the same voltage against the ampere at the primary side.
What should be the value of variable rsistor.
Will my problem solve after adding variable resistor, let suppose my maximum current is 0.3 ampere i need to built 100 circuits after adding variable resistor i tune at DC side 3 VDC at 0.3 ampere at primary side, if my current consumption decreases to 0.1 ampere do the ratio of voltage drop will same in all 100 circuits i built or not.
