variable question in VHDL
Digit0001
Member level 1
Hi
Can someone tell me if this is true, Variables declared inside a clocked process are treated as signals for the purpose of synthesis.
P.S
Variable this is definition your task like combinatorial logic. For correct synthesis of it you need connect this combinatorial logic to triger.
The answer is that you're kind of correct.
Variables are converted to logic just like any signal, but the position of the variable in the code has an effect whereas a changing the position of a signal would have no effect. Because variables are updated immediatly they can be used to create combinatorial logic inside a clocked process.
an example. The first two processes are identical.
process
begin
  if rising_edge(clk) then
    a <= input;
    b <= a;
    c <= b;
    output <= c;
  end if;
end process;
process
begin
    output <= c;
    c <= b;
    b <= a;
    a <= input;
  end if;
end process;
Both of these processes produce exactly the same logic - a shift register that has a delay of 4 clock cycles.
now the same codes using variables:
process
begin
    a := input;
    b := a;
    c := b;
    output <= c;
  end if;
end process;
In this case, because variables are updated immediatly, then the output only has a single register between the input and output.
process
begin
    output <= c;
    c := b;
    b := a;
    a := input;
  end if;
end process;
In this process, the synthis will produce the same logic as if a,b and c were signals, because you are using the variable before it is updated with new value - hence it places a register (so output is a 4 clock cycle delayed version of input).
ok i understand now
---------- Post added at 10:35 ---------- Previous post was at 10:31 ----------
however in general cases would this happen regularly? I assume most people when designing would not want a code to wait four clock cycles to update a signal.
This is a simple example, showing the behaviours of signals and variables. You may want a shift register of N delay to keep control signals aligned with a data pipeline. So your question doesnt make a lot of sense, because it all depends on your design.
As a general rule - unless you understand what you're doing, use signals. Variables used wrongly can cause problems. You probably wont go wrong with signals.
