Variable L in VSM - looking for a simulator model
nitr8
Member level 3
Member level 3
Look behind
Any one where is the variable inductor in proteus VSM. I'm looking for a simulator model
S
sick_man
Newbie level 1
a thing to note about proteus spice sim
when you want to model an inductor
simply place the inductor part
and open the component to edit it
then tick the attach hirachie module
close the edit window
pass over the component with the mouse in the center of it
and press on the keyboard ctrl X
then you will be taken to a blank
dsn schematic layout {the upper circuit {as opposed to subcircuit }
much like an inductor rises from a plane....
the plane being the part
so....
to make an inductor model in a vsm
you use R and C to determine L
by using bridging RC theorie
then combinations of R's and C's and other upper models using the mutual= properties for coil stage couplings between models within models
{for complex inductors}
for simple inductor a single R and C
is all that is needed plus a define to give an overall value state relative to resonace and reactance ....
where appropreate....
all relative to or as a means of setting /adjusting in time the actual
overall L of the coil
<font size=-1>[ This Message was edited by: SIMBOX on 2002-05-02 06:06 ]</font>
<font size=-1>[ This Message was edited by: SIMBOX on 2002-05-02 06:15 ]</font>
S
sick_man
Newbie level 1
moreover to vary L you simply vary c relative to R
and R relative to C by r and c
so R + - r relative to C + - c
