Guyz
Need help. I've read that V-PNP advantage is better speed than L-PNP while L-PNP has less noise than V-PNP. But V-PNP has smaller size, and this extra advantage that makes V-PNP looks better than L-PNP.
But, in term of cross-section wise, the V-PNP substrate is connected to GND so V-PNP has to be used as common-collector.
Does this the reason that limit the usage of V-PNP?
Or is the V-PNP can actually be use as common-emitter?
In circuit design, which is prefferd, L-PNP or V-PNP?
