chewqf
Help!!! I was doing a UWB circular monopole antenna using MWO and could not able to get a desired return loss s11 and radiation patten. I wondered what could i gone wrong?
The antenna was to operate at a frequency range of 2-10GHz and i set the step as 1-2Ghz interval.
Thickness=1.575mm; Er=2.33; losstangent=0.0012
via port = 0.5mm and pitch of 1mm
circular monopole of radius 7.5mm
X-dimension=20mm
Y-dimension=40mm
Shielded Stripline of 2mm in between of a dual layered ground planes and terminated at end.
I tried putting a notch conductor to integrate the striplines to the circular monopole and I wasn't sure is this the results that I would be getting.
So anyone please help out...
X-dimension=20mm
Y-dimension=40mm
