[SOLVED] uvision 4 target not created............
vinothsami89
Newbie level 2
hi frns,
i'm using uvision 4 evaluation software for lpc2148 microcontroller.
i'm new to keil.please tell how to create a new project.........
1. clearly mention the error you are getting....
2. put a snapshot of the error in keil window...
3. try to run a example program given in the keil installed directory and see what happens...
4. did you add the start-up code to your project??
Thank u very much sir.i got the answer.just i check the example programs and found out the error.i forget to add lpc2148 from device database(nxp) and start-up code.i add arm7 only thats y error occur. thank u very much............
