Using VHDL generic and configuration after synthesis to verilog netlist
Hi all,
Actually, all of my designs is VHDL file and use 'generic' and 'configuration' features.
Although I synthesized VHDL files to the verilog netlist, test bench files are still VHDL.
You know, sysnthesis tools such as DC don't support 'generic' and 'configuration'.
My question is how can I use only one test bench file in case of both RTL simulation and gate-level netlist simulation.
The most simple solution is just deleting generic and configuration lines in gate-level simulation. But I want use this tb in case of RTL sim(VHDL) and gate-level sim(verilog) like as '#ifdef' in C language.
For example, following code is part of a VHDL test bench.
Code VHDL - [expand]
8
9
10
11
12
INST1 : TOP_MODULE
genericmap(
length =>5)
configuration CFG_TB of TB isfor behavior
for INST1: TOP_MODULE
useconfigurationWORK.CFG_TOP_MODULE;endfor;endfor;end CFG_TB;
We face this issue during multiple projects, to solve, that we have two top_tb:
1- RTL code with generic and the test-bench.
2- netlist and the same test bench.
You are right. I could make two seperate top_tb, but I just want a way using only one test bench.
Maybe, there is no other way.
Thanks.
After synthesis using DC, some VHDL features such as generic, configuration is removed.
That's why I refered to DC. Because verilog netlist don't have generic and configuration, the same VHDL testbench will not be compiled.
I think rca's method is right answer. But I just want to more simple way to use only one testbench.
Maybe... there is no another way...
Thanks.
