Using ULN2003 to control 5 light bulbs
wilson82
Newbie level 6
From my research ULN2003 is use for high voltage /current driver. Im currently trying to connect up a circuit which i be using ULN2003 to control 5 light bulbs.
wat kind of diodes i need to use in the circuit? and is there other component i need to add to the circuit.?
My boad will link to motorola hc11.
thanks for replies.` =)
gam
uln2003
What is the power consumption of your bulbs? you have to check their current against the current max that can be provided by the ULN2003.
You won't need diodes unless you want your bulbs to act like LEDs: light up only when current passes through a certain direction.
meax98
Full Member level 3
what is uln2003a
Just take a look at picture and you will understand! The text is about basic stamp, but for any uC is the same thing.
regards
meax98
wilson82
Newbie level 6
what is uln2003?
thanks for the replies.. =)
jus tested the car light bulbs and bulbs for tourch light. the car one draw very high current... haiz... still looking for a suitable one.
