Using the -> operator in C language
shaiko
Advanced Member level 5
Hello,
What does the C -> operator do?
How does it work?
Please post an example.
Hello!
The -> can be used for a pointer, the . can be used for an actual object.
Example:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
typedef struct {
    int a;
    int b;
} AStruct;
//    Case 1: an actual instance
AStruct MyAStruct;
//   If you want to access member a or b, you use .
MyAStruct.a = 1;
MyAStruct.b = 2;
//    Case 2: a pointer
AStruct * MyAStrucyPointer;
MyAStructPointer = &MyAStruct;
//    In this case, if you want to access the members through the pointer:
MyAStructPointer->a = 1;
MyAStructPointer->b = 2;
Well, I don't see anything else to add.
It's like the phone. If you talk to somebody close to you, you talk directly, otherwise, you talk through the phone.
Dora.
Reactions: shaiko
    shaiko
Thanks a lot.
Is there a different syntax that can do the same thing - without using the -> operator ?
Hello!
If you want to do it without the -> operator, just take the actual instantiation of your structure / object.
Anyway in the embedded world, you usually don't use memory allocation, therefore you can always
find an actual instanciation of some kind. For example, if you use MyAStruct somewhere, you can
declare anywhere in your program as extern AStruct MyAStruct, in which case you don't need a pointer
to access it.
By the way, why are you afraid of -> ?
Dora.
Reactions: shaiko
    shaiko
If we presume that your code is using a pointer to a structure for a good reason (e.g. because multiple objects of the same type are accessed) there's no reasonable alternative. If the pointer is accessing a simple array of structure, using the array index can be an alternative, as in the below example. x and y are assigned with the same data. Which variant is more efficient strongly depends on the processor architecture and compiler intelligency.
Code C - [expand]
8
9
10
11
12
13
14
15
16
typedef struct
  int a;
  char b;
} STRUCT1, *PSTRUCT1;
STRUCT1 s[10];
PSTRUCT1 ps;
int i;
int x;
int y;
for (i=0, ps = s;i<10;i++,ps++)
  x = ps->a;
  y = s[i].a;
Reactions: shaiko
    shaiko
Not afraid - I want to be familiar with more ways to do the same thing so I recognize when I see them...
