Anyone use Sunsom - Atmel 89 Series Device Programmer ( **broken link removed** ) to lock the MCU before?
I'm using ProLoad V4.1 for 89 Series Programmer.
May i know what's the function for "Set lock bytes after writing"?
Is it after the mcu(at89c52/2051) has been programmed, we will not be able to read the information on the mcu? and it is protect our firmware from duplication?
I have already tested, tick the function when burning it. After finished burn it show "Write and Lock Successful" and "AT89C52 0 bytes used" message. But when i took out the mcu and do some application testing it couldn't work?
Please kindly help me. I haven't play the lock MCU before.
provided, your programmer is operating correct, you should consider the restrictions regarding external memory access and EA pin function implied with the applied Lock Bit Mode. See AT89C52 data sheet for details.
After the lock bits are set, you can not verify/test it anymore .. the MCU is just locked ..
But, as far as application is concerned, whether you set the lock bits, or not, it really doesn't matter ..
If the MCU is programmed properly, it should work ..
What does you mean the programmer is operating correct? I'm not sure what's the datasheet mean. Is it if the /EA is connected to GND means that it allow any external program memory to program into AT89c52? As i know as normal operation mode the AT89C52 /EA must connected to +5Vcc.
How bout AT89C2051 it doesn't have /EA pin?
Hi Ianp fren,
You mean..after the MCU is locked we can't do any verify/testing it anymore another way we can say that...after the locked bit is set the MCU will lock it with empty data in the flash memory? So, what for we have to lock the MCU? after MCU is lock we can't use that MCU anymore in our testing or our application?
But, as far as application is concerned, whether you set the lock bits, or not, it really doesn't matter .. If the MCU is programmed properly, it should work ..
Now i start confusing with the MCU lock already...I already study the datasheet for C52 and C2051. Please teach me how to read the table..
Is it we have to define the Lock Bits in our coding so that we can lock our MCU?
