Using shift register and MUXF7 to realize dual-Clock FIFO
EDA_hg81
Advanced Member level 2
dual clock fifo +xilinx
Can I use MUXF7 as a switch to select one of two clocks for realizing shift register based dual-clock FIFO?
Thanks.
echo47
Advanced Member level 5
USA
I assume you are referring to a Xilinx FPGA. I'm not clear exactly what you are building, but if you really need to switch between two clocks without glitches, try the BUFGMUX (if your FPGA provides it) instead of an ordinary mux such as MUXF7.
If possible, try to design synchronous logic that doesn't require gating or switching clocks.
    EDA_hg81
EDA_hg81
Re: Using shift register and MUXF7 to realize dual-Clock FIF
Thanks.
Just for building a dual clock FIFO.
But BRAM based dual clock FIFO is big, I only need 16 byte deep.
mpatel
Member level 4
Germany
EDA_hg81 said:
Thanks.
Instead of BRAM, use Distributed RAM based FIFO. It is synthesized as LUT only and does not consume any of BRAM on FPGA chip.
If you are using Xilinx FPGA, please refer XILINX Core Generator IP CORE guide.
Enjoy!!!
    EDA_hg81
