[SOLVED] Using Remote ON/Off in Traco power DC/DC converter
AWahab
Junior Member level 1
Pakistan
can anyone tell me how to use Remote on/off pin in traco power DC/DC converters? :bang:
Regards,
AW
Generally it is about switching off the output supply by making it high or low whichever is mentioned in the datasheet. What is the which you are asking for?
Reactions: AWahab
    AWahab
Thanks hobbyckts.
I am using THN 15-1221 with 12V power. Its +-5V dual voltage regulator. I just want it to run it all the time. Can I connect it directly with 12V power supply?
The reason not to switch is because I will install the switching ckt for +5V and -5V independendently and this regulator gives me the possibilty of on/off both +-5V with the single input.
reading the datasheet gives that information within 10 seconds (inclusive google search, download and opening PDF):
Remote On/Off
– On: 3.0 ... 15 VDC or open circuit
– Off: 0 ... 1.2 VDC or short circuit pin 6 and pin 2
– Off idle current: 2.5 mA
What else do you need?
Reactions: AWahab
    AWahab
Connect the pin to ground if you don't want to use it.. It is mentioned in the datasheet itself..But anyway all the best
Reactions: AWahab
    AWahab
