using PWM as a DAC for audio output
electroman2000
Member level 2
Member level 2
Hi everyone, I'm going to realize an audio player with a PIC32, using PWM as a DAC for audio output.
I have not write any code yet, because I want to understand deeply the theory behind it.
I stored a .WAV file, 44.1 Khz sample rate, 16 bit, in a SD card, in a previous part of code. Now i want to reproduce this audio trought PWM. Because I use mikroC, I looked at PWM library, but there isn't trace about the sample that I want to reproduce; then I think I'm missing something.
Can you help me?
Thank you.
To achieve 16 bit resolution with 44 kHz sampling rate using regular PWM, you would need about 3 GHz pwm clock. That's obviously not feasible.
Some kind of sigma-delta modulation is necessary.
Thank you for reply. Just my curiosity, what kind of equation did you use for obtain the 3 Ghz value?
So finally I think i will use a external DAC.
So let's me say what I understand, and tell me if it is correct. I have 16 bit, so for each sample I have a time window of 1/2^16. Each sample is expressed by a variation of duty cicle of the pulse in this time window; for example if all bits are 1, the duty cicly is 100%, for all bits are 0, the duty cicle is 0%. Whatever is the value, each sample have a fixed time window of 1/2^16, so a frequency of 65535. In one second I want 44.1k samples, so the total frequency is 65535*44.1k=2,88 Ghz.
It is correct?
That's my calculation.
As already mentioned, modern DACs are taking a different approach to achieve high resolution with moderate switching frequency. A basic single-bit sigma-delta DAC outputs a binary sequence in low MHz range that can represent the analog signal much more accurate than a pwm signal.
Thats not correct calculation. Each sample should be integrated from at least of 10 PWM cycles. So, we are talking about 30GHz PWM frequency. :laugh:
I'm thinking about it and I'm a bit confuse. In particular I don't understand why each bit of sample needs a PWM cycle. I agree with Easyrider83, 10 cycles for a samples is necessary for obtain a correct average value. But I still don't understand why each bit needs a PWM cycle.
Suppose I want an analog value of an half of logical swing. The 16 bit digital value is one 1 followed by fifteen 0. If I have a PWM frequency of 44.1Kh*10, 441 Khz, I have a time window of 1/441KHz, about 2.2 us. In this 2.2 us I have a PWM pulse with 50% duty cicle. Then, in 1 "wave sound cycle", made by 22 us (1/44 Khz), I have 10 PWM pulse with 50% duty cicle, that outputs an average analog value of 50% of the voltage value of logic 1; for example if logic 1 is 5 V, the output should be 2.5 V.
Why this example shouldn't work?
It's of limited sense to calculate a method that can't be practically implemented. You have to specify the reconstruction filter. But using 44 kHz PWM cycle isn't worse than a DAC with 44 kHz sampling rate.
