using of transistor 2sc4059 in place of 2sd1047
ch wazir
Full Member level 3
lahore
hello Forum,
Can one use 2sc4059 having vcbo 600v in place of 2sd1047e having vcbo 160v,a bit detailed response will be appreciated.
2SD1047 is a power transistor rated 160V, 12A , 100W
2SC3263 rated 230V , 15A 130W having same metal tab connected
to collector will be the best substitute
hello Forum,
\dear wazir
i want to learn about the application and how to use D1047. Kindly help me out
Yes you can use it, if application is not a special one. Rather it is more safe on higher voltage supply than 2SD1047.
