Using limiter and VGA in a receiver
fanshuo
Full Member level 5
Netherlands
can anybody give me some comparisons of these two options in receiver?
and why in GFSK zero-IF receiver limiter is not a good choice?( why those low frequency components in GFSK spectrum cause trouble?)
Thanks
Re: limiter and VGA
I think the VGA has larger linearity than limiter.
limiter and VGA
the VGA is need for any AGC loop and sure most of the receiveres need this AGC
about the limiter is used to eliminate any amplitude variations
i think they will both employed in FSK and GMSK
khouly
Re: limiter and VGA
Hi Khouly,
In the paper below it discussed the receiver architecture for GFSK. It rules out the zero-IF saying:
low frequency components of the GFSK spectrum produce harmonics that inside the signal bandwidth when converted to zero frequency. This degrades the SNR.
I do not quite understand
limiter and VGA
i checked the paper , it seems , that this is a result of high gain of the limiter , so it will distorted the signal , specially , there will be alot of nonlinearities
khouly
    fanshuo
limiter and VGA
but if the limiter is so nonlinear, it should also degrade the signal power due to its 3rd-order nonlinearity product in the low-IF structure
isn't it?
limiter and VGA
this also may happen
khouly
Re: limiter and VGA
because GFSK has considerable spectrum energy around DC, so about zero-IF architecture, limiter is not used for DC offset may degenerate the SNR, but in low-IF architecture ,limiter is suitable.
