using laserjet to make pcb
david90
Advanced Member level 1
Can you use a laserjet printer to make PCB or only laser printer?
Thanks
Well using a laser printer you can get the layout's tracks on a transparrency (white solid plastic cut in the shape of A4 Paper used for lecture presentations), then you can cut those tracks and then place it on the copper sheet and move the marker over on the cut portion in order to make visible tracks on the sheet and place the board in Ferric Chloride to remover the useless copper then go for drilling and all.
Best Regards
serch on the google for toner transfer method of pcb making.
in this method u will print ur layout on a glossy paper and the put the paper on the copper sheet use hot cloth iron for 1minute on it.put the iron on the glossy paper with ur full force and dont move the iron.it will transfer ur layout on the copper sheet.then put it in ferric cloride
