Using iButton like an on/off switch
jeppix
Hello to everybody!!!
I need help...
I'd like to use ibutton like on-off switch... in other words I've a circuit in witch there is a switch that could be open or close and I'd like to substitute it with an ibutton.
Could someone help me?
Thank you.
Andrea
Re: iButton
Andrea, do you have experience with PIC?
Re: iButton
Hi predrage
I start studing PIC but at the moment I'm real novice :cry:
Could you help me?
Andrea
Re: iButton
Which tool are you using for programming (MpLab, Mikro C,...)?
Re: iButton
I'm starting with the MikroBasic
Re: iButton
before you use the ibutton you must now how to comunicate using 1Wire interface, about the controller you an use anything.
Re: iButton
Mikro Basic has 1-wire library already implemented, so this isn't a problem.
The problems are the circuit and the PIC program... :cry:
Re: iButton
Micro Basic should have examples directory in program files/microbasic. There you will find whole ibutton application for easy pic development board. I am using micro C
and mikro C have example for ibutton.
