Using I2C protocol in 8051
CosaNostra
Junior Member level 1
Lahore
In case i just need to use one device only do i still have to load the I2c drivers
and can i use more than one device and interface them on separate pins without loading the drivers hope my questions are clear
i2c in 8051
Hi CosaNostra,
Your questions are not quite clear. Are you saying that you are not going to use the I2C engine but intend to interface the I2C slave device using GPIOs?
i2c with 8051
hi
if you familiar with I2C protocol ,each deviece have a address in I2C BUS. these address may be setted by connecting pin to H or L .
In this protocol ,master deviece make a start signal and send add .Slave deviece that matched with this address send and acknowledge .
finaly master send a Command and wait for another acknowledge.
In end a stop signal send by master for end of comunication.
i2c protocol 8051
smxx said:
hi
yup exactly i want to use the device but i want to know if it is necessary to use I2c protocol even if it i one device
8051 as i2c slave
Yes, you have to follow the signal condition or you will get nothing at all.
The slave device responses only when its designated address is matched.
8051 i2c
CosaNostra said:
smxx said:
hi
yes you can, if your boss allows the cost.
i2c +slave +8051
sci-3d said:
An example:
h**p://mcu-programming.blogspot.com/2006/09/ic-bus-interfacing.html
This link does not work at all
