Using DCM with Spartan 3
agent_009
Member level 2
I want to know that what is the exact method of getting a clock using DCM(Digital Clock Manager) for Xilinx Spartan 3 FPGA. Currently i am using ISE 6.0
Thanx in advance
yasser_shoukry
Full Member level 4
Cairo - Egypt
You can use IPcore generator from ISE to create an instance from the DCM with the required parameters.
    agent_009
echo47
Advanced Member level 5
USA
Please define more clearly "getting a clock". There are different ways of using a DCM depending on what you need to do. Many designs don't need any DCMs.
You can use coregen to build a DCM core as yasser_shoukry suggested, or you can instantiate the DCM primitive directly into your HDL (see the DCM section of your ISE Libraries Guide).
    agent_009
agent_009
Member level 2
I have used the core for "Single DCM" and added it into my project. But when i configure it on the Spartan 3, it uses it's default clock rather than the DCM component i have added.
How can i make it use the DCM generated clock instead of it's default clock?
echo47
USA
You need to instantiate the DCM core in your HDL, and then connect the core's inputs and outputs to wherever you need them to go.
