anccc
Newbie level 3
- Joined
- Apr 9, 2013
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Estonia
- Activity points
- 1,363
Hello!
I'm fairly new to this board and to FPGA/VHDL in general, but I've had some courses in the subject before. What I'm trying to do is to implement a sort of a music sheet, where different notes can be placed according to given signals. I would also like to have the note pixels stored preferrably in a block RAM (or any easy way of storing pixels I'm currently ) according to the previous shown location so that when I move the note around, a sort of a copy of the note is placed in that location that stays there. At the moment, I'm using a single clef to move around in a small area for testing if the placement stays the same when I move the clef to another location but I'm unable to have the clef displayed in the previous location. I have a working VGA controller using 640*480 resolution and I have inferred a block RAM using examples, I've found on the Internet. I am using a Basys2 board with 250k logic gates. Here is what I've done so far:
I have defined the note/clef in a 2 dimensional array like this
And I use this code to draw out the clef. I've also set EN and WE to '1' so I could forward the dataOut to the BRAM I have inferred in another file and defined the BRAM address
I inferred my BRAM as an array of std_logic:
Now I checked the console log and I see that the BRAM is inferred as I expected. I am able to get the image just fine and as it is going through the memory, all the '1' and '0' pixels should be stored in the RAM, shouldn't they? The problem is that when I move the location on the screen, like this:
the image moves, but the previous location is still blank. I though that if I could make a counter which goes through the contents of the RAM like I did with Counterproc, I should at least get some values to send back to the image controller and show as colour red, but I don't see anything other than the blue clef. I'm obviously doing something wrong with reading/writing into the RAM and I don't understand it very well. Any criticism would be appreciated. Also if there is another much easier or more efficient way of storing the image, I would be grateful. I will also attach the .vhd files if anyone is interested.
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 type clefGenType is array (0 to 35) of std_logic_vector(15 downto 0); -- two-dimensional array for storing clef pixels constant clefGenLT : clefGenType := ( conv_std_logic_vector( 1024 , 16), conv_std_logic_vector( 1536 , 16), conv_std_logic_vector( 3840 , 16), conv_std_logic_vector( 2944 , 16), conv_std_logic_vector( 2176 , 16), conv_std_logic_vector( 2176 , 16), conv_std_logic_vector( 2176 , 16), conv_std_logic_vector( 2176 , 16), conv_std_logic_vector( 3200 , 16), conv_std_logic_vector( 3200 , 16), conv_std_logic_vector( 1664 , 16), conv_std_logic_vector( 1920 , 16), conv_std_logic_vector( 960 , 16), conv_std_logic_vector( 480 , 16), conv_std_logic_vector( 496 , 16), conv_std_logic_vector( 504 , 16), conv_std_logic_vector( 316 , 16), conv_std_logic_vector( 1950 , 16), conv_std_logic_vector( 4046 , 16), conv_std_logic_vector( 7654 , 16), conv_std_logic_vector( 14694 , 16), conv_std_logic_vector( 12662 , 16), conv_std_logic_vector( 12662 , 16), conv_std_logic_vector( 13174 , 16), conv_std_logic_vector( 12902 , 16), conv_std_logic_vector( 12868 , 16), conv_std_logic_vector( 12940 , 16), conv_std_logic_vector( 6680 , 16), conv_std_logic_vector( 3632 , 16), conv_std_logic_vector( 1984 , 16), conv_std_logic_vector( 1024 , 16), conv_std_logic_vector( 1040 , 16), conv_std_logic_vector( 1080 , 16), conv_std_logic_vector( 1592 , 16), conv_std_logic_vector( 784 , 16), conv_std_logic_vector( 480 , 16) );
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 -- NOTE* constants and signals used for placement and drawing of image -- adrHor: in integer range 0 to cstHorSize - 1; -- pixel counter (800;-- cstHorAl + cstHorFp + cstHorPw + cstHorBp; -- pixel/total line) -- adrVer: in integer range 0 to cstVerSize - 1; -- lines counter (521 --cstVerAf + cstVerFp + cstVerPw + cstVerBp; -- lines/total frame) -- constant cstHorPlayFieldSize: integer := 128; -- constant cstVerPlayFieldSize: integer := 128; -- constant cstHorPlayFieldPos: integer := cstHorAl/2 - cstHorPlayFieldSize/2; -- Al - active line -- constant cstVerPlayFieldPos: integer := cstVerAf/2 - cstVerPlayFieldSize/2; -- Af - active frame -- constant clefSizeHor: integer := 16; -- clef horizontal size in pixels -- constant clefSizeVer: integer := 36; -- clef vertical size in pixels -- signal clefPix : integer range 0 to clefSizeHor - 1; -- horizontal position within the clef -- signal clefLine : integer range 0 to clefSizeVer - 1; -- vertical position within the clef -- signal cntClefPosHor: integer range 0 to cstHorPlayFieldSize - 1 := cstHorPlayFieldSize/2; -- signal cntClefPosVer: integer range 0 to cstVerPlayFieldSize - 1 := cstVerPlayFieldSize/2; adrClefBRAM <= conv_std_logic_vector(cntClefPosHor + cntClefPosVer * cstHorPlayFieldSize, 14); -- should total 16383 - 1*16kbit RAM clefLine <= adrVer - cntClefPosVer; clefPix <= adrHor - cntClefPosHor; drawClef : process (ck25MHz, adrHor, adrVer, cntClefPosHor, cntClefPosVer) begin EN <= '1'; WE <= '1'; if ((adrHor >= cntClefPosHor and adrHor < cntClefPosHor + clefSizeHor) and (adrVer >= cntClefPosVer and adrVer < cntClefPosVer + clefSizeVer)) then dataOut <= clefGenLT(clefLine)(clefPix); else dataOut <= '0'; end if; end process; red <= "111" when sendSignal = '1' else "000"; blue <= "11" when DataIN = '1' else "00";
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use ieee.std_logic_unsigned.all; entity rams_01 is Port ( ck25MHz : in STD_LOGIC; WE : in STD_LOGIC; EN : in STD_LOGIC; ADDR : in STD_LOGIC_VECTOR (13 downto 0); --adrClefBRAM DI : in STD_LOGIC; DO : out STD_LOGIC; sendSignal : out STD_LOGIC ); end rams_01; architecture Behavioral of rams_01 is type ram_type is array (16383 downto 0) of std_logic; signal RAM: ram_type; constant arrayLength : integer := 16384; signal counter : integer range 0 to arrayLength - 1; begin RAMproc : process (ck25MHz) begin if ck25MHz'event and ck25MHz = '1' then if EN = '1' then if WE = '1' then RAM(conv_integer(ADDR)) <= DI; -- dataOut end if; DO <= RAM(conv_integer(ADDR)); --dataIN end if; end if; end process; Counterproc: process (ck25MHz) begin if ck25MHz'event and ck25MHz = '1' then if counter < arrayLength - 1 then if RAM(counter) = '1' then sendSignal <= '1'; -- for the colour controller to display as red else sendSignal <= '0'; end if; counter <= counter + 1; else counter <= 0; end if; end if; end process; end Behavioral;
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 HorMovement: process(ck10Hz) begin if ck10Hz'event and ck10Hz = '1' then if btnRight = '1' then if cntClefPosHor < cstHorPlayFieldSize - 1 then cntClefPosHor <= cntClefPosHor + clefSizeHor + 10; end if; elsif btnLeft = '1' then if cntClefPosHor > 0 then -- starting position cntClefPosHor <= cntClefPosHor - clefSizeHor - 10; end if; end if; end if; end process;
