Using BRAM in FPGA(Xilinx Spartan) with MOST ORIGIN VHDL
TuAtAu
Jupiital
Hi Guys,
Does anyone have any example code that able to let the synthesiser to synthesis the pure VHDL code into the BRAM?
I don't want to use core gen.
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
library IEEE;
use IEEE.std_logic_1164.all;
-- Syntax for Synopsys FPGA Express
-- pragma translate_off
library UNISIM;
use UNISIM.VCOMPONENTS.ALL;
-- pragma translate_on
entity XC3S_RAMB_1_PORT is
port (
DATA_IN    : in std_logic_vector (35 downto 0);
ADDRESS    : in std_logic_vector (8 downto 0);
ENABLE     : in std_logic;
WRITE_EN   : in std_logic;
SET_RESET  : in std_logic;
CLK        : in std_logic;
DATA_OUT   : out std_logic_vector (35 downto 0)
end XC3S_RAMB_1_PORT;
architecture XC3S_RAMB_1_PORT_arch of XC3S_RAMB_1_PORT is
-- Components Declarations:
component BUFG
port (
I : in std_logic;
O : out std_logic
end component;
component RAMB16_S36
generic (
-- "Read during Write" attribute for functional simulation
WRITE_MODE : string := "READ_FIRST" ; -- WRITE_FIRST(default)/ READ_FIRST/
--NO_CHANGE
-- Output value after configuration
INIT : bit_vector(35 downto 0) := X"000000000";
-- Output value if SSR active
SRVAL : bit_vector(35 downto 0) := X"012345678";
-- Initialize parity memory content
INITP_00 : bit_vector(255 downto 0) :=
X"000000000000000000000000000000000000000000000000FEDCBA9876543210";
INITP_01 : bit_vector(255 downto 0) :=
X"0000000000000000000000000000000000000000000000000000000000000000";
--... (snip)
INITP_07 : bit_vector(255 downto 0) :=
-- Initialize data memory content
INIT_00 : bit_vector(255 downto 0) :=
INIT_01 : bit_vector(255 downto 0) :=
--... (snip)
INIT_3F : bit_vector(255 downto 0) :=
port (
DI   : in std_logic_vector (31 downto 0);
DIP  : in std_logic_vector (3 downto 0);
ADDR : in std_logic_vector (8 downto 0);
EN   : in STD_LOGIC;
WE   : in STD_LOGIC;
SSR  : in STD_LOGIC;
CLK  : in STD_LOGIC;
DO   : out std_logic_vector (31 downto 0);
DOP  : out std_logic_vector (3 downto 0)
end component;
-- Attribute Declarations:
attribute WRITE_MODE : string;
attribute INIT: string;
attribute SRVAL: string;
-- Parity memory initialization attributes
attribute INITP_00: string;
attribute INITP_01: string;
--... (snip)
attribute INITP_07: string;
-- Data memory initialization attributes
attribute INIT_00: string;
attribute INIT_01: string;
--... (snip)
attribute INIT_3F: string;
-- Attribute "Read during Write mode" = WRITE_FIRST(default)/ READ_FIRST/
--NO_CHANGE
attribute WRITE_MODE of U_RAMB16_S36: label is "READ_FIRST";
attribute INIT of U_RAMB16_S36: label is "000000000";
attribute SRVAL of U_RAMB16_S36: label is "012345678";
-- RAMB16 memory initialization for Alliance
-- Default value is "0" / Partial initialization strings are padded
-- with zeros to the left
attribute INITP_00 of U_RAMB16_S36: label is
attribute INITP_01 of U_RAMB16_S36: label is
--... (snip)
attribute INITP_07 of U_RAMB16_S36: label is
attribute INIT_00 of U_RAMB16_S36: label is
attribute INIT_01 of U_RAMB16_S36: label is
--... (snip)
attribute INIT_3F of U_RAMB16_S36: label is
-- Signal Declarations:
-- signal VCC : std_logic;
-- signal GND : std_logic;
signal CLK_BUFG: std_logic;
signal INV_SET_RESET : std_logic;
begin
-- VCC <= ’1’;
-- GND <= ’0’;
-- Instantiate the clock Buffer
U_BUFG: BUFG
port map (
I => CLK,
O => CLK_BUFG
-- Use of the free inverter on SSR pin
INV_SET_RESET <= NOT SET_RESET;
-- Block SelectRAM Instantiation
U_RAMB16_S36: RAMB16_S36
port map (
DI   =>  DATA_IN (31 downto 0),  -- insert 32 bits data-in bus (<31 downto 0>)
DIP  =>  DATA_IN (35 downto 32), -- insert 4 bits parity data-in bus (or <35
--   downto 32>)
ADDR =>  ADDRESS (8 downto 0),   -- insert 9 bits address bus
EN   =>  ENABLE,  -- insert enable signal
WE   =>  WRITE_EN, -- insert write enable signal
SSR  =>  INV_SET_RESET, -- insert set/reset signal
CLK  =>  CLK_BUFG, -- insert clock signal
DO   =>  DATA_OUT (31 downto 0), -- insert 32 bits data-out bus (<31 downto 0>)
DOP  =>  DATA_OUT (35 downto 32) -- insert 4 bits parity data-out bus (or <35
--   downto 32>)
end XC3S_RAMB_1_PORT_arch;
Does this code is the most origin? I want even more origin! only pure VHDL describe, exclude attribute~
Thanks
You can find an example in ISE under template. You will see something like:
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
process (<clockA>)
begin
   if (<clockA>'event and <clockA> = '1') then
      if (<enableA> = '1') then
         if (<write_enableA> = '1') then
            <ram_name>(conv_integer(<addressA>)) := <input_dataA>;
         end if;
         <ram_outputA> <= <ram_name>(conv_integer(<addressA>));
      end if;
   end if;
end process;
process (<clockB>)
begin
   if (<clockB>'event and <clockB> = '1') then
      if (<enableB> = '1') then
         if (<write_enableB> = '1') then
            <ram_name>(conv_integer(<addressB>)) := <input_dataB>;
         end if;
         <ram_outputB> <= <ram_name>(conv_integer(<addressB>));
      end if;
   end if;
end process;
Also, if you want to instantiate a BRAM primitive of the device you selected, you can find it on user's guide. It talks about what primitive to use, how to initialize, etc.
Gongdori
Hi Gongdori,
<ram_outputB> <= <ram_name>(conv_integer(<addressA>));
Its an array~
r u sure arrays in a VHDL code are put into BRAM by default?
PS: the #1 post is from the user's guide template. I am not sure it is the origin VHDL? but i saw it call a library and using a predefined RAM module. I want to instantiate myself with only VHDL code.
Yes. It is an array which is accessed by two ports. Synthesizer should interpret it as a dual port memory.
I've done both ways and they worked.
If you want to target one specific device, I recommend to use the primitive from user's guide because it tells the tool what primitive to use. However, if you need to write a generic BRAM, behavioral model would be better.
    TuAtAu
    thanks for helps in BRAM!
OK! got it! tried in simulation and implementation!
for array of type BYTE_RAM_TYPE is array (0 to 2047) of std_logic_vector(31 downto 0);
(summary)
Number of RAMB16BWERs used:4 available:126 3%
Thanks Gongdori!
