How can I use instances from bmsLib, which have veriloga and verilogams views, in a spectre simulation? I added veriloga and verilogams to the beginning of my switch view list and the circuit netlists without warning/error, but the state of the instance does not change when an input is given. I can't even get an inverter to work. Do i have to use inputs other than those in analogLib?
Verilog-A and VerilogAMS are understood by spectre without needing any additional care (no need for special sources or interface elements as you would need for pure verilog cells and mixed-signal simulation).
The inverter cell has a default threshold voltage of 1.5V therefore if you are using 1V logic it won't change.
