I want to have a diode connected NMOS in a 3D CST simulation. I just want a wire loop and in this wire loop, there is a port and this lumped transistor model.
I simply want to have this in a full 3D simulation.
It would look like this (maybe), except, instead of a diode, there would be a transistor model.
I would like to be able to change the transistor model, but I can just start with a random model such as
Just to be clear, Microwave Studio can indeed simulate diodes just fine and it allows you to use a .cir/.net file as a lumped element
I realize diodes are technically passive, but i only intend to put in a diode connected transistor, with no additional biasing or anything. It seems like it should be possible.
But the model which you have written above is a nonlinear MOS model.CST cannot understand those statements..
All you can do is to linearize that diode as you have remarked so diode will have simple small signal AC model..Possible ?? Try..
But If I were you, I transfer that layout/system/circuit (?) onto Keysight ADS Design Environment if you're able to launch, then I would do my simulations with true nonlinear model..
You should check if the excitation level can be changed without repeating the EM analysis of the linear passive model parts. It would be inefficient to repeat the EM calculation if only the diode response changes. That's why we usually split into active part (nonlinear, lumped) and EM part (linear, distributed), for workflow efficiency reasons.
