Using a Crystal on a Breadboard
Kittu20
Member level 2
Member level 2
Hello Everyone
I was previously using the internal oscillator for my PIC microcontroller, but now I want to switch to a crystal for better accuracy. My setup is currently on a breadboard, and I plan to use a crystal along with two ceramic capacitors on breadboard setup.
I’m curious—will using a crystal on a breadboard cause any connection or stability issues?
Keep the leads short and snug to uC ground pin along with denoising caps.
If driving any logic more than a few inches, 5cm add a series damping resistor like 22 to 33 ohms or more
If driving high current be careful about sharing ground and power use the lowest impedance source.
Think of the breadboard the same way as a regular PCB. Once each connection track below the grid can act as an antenna for RF signals, it could be beneficial to ground the unused tracks in the vicinity.
If you're talking "solderless breadboard", this has
a lot of "stray C" and some unknown contact
resistance per connection, which can bleed or
damp the crystal loop. The circulating AC current
loop quality is key - loss and contamination,
"injection unlocking (ground beat-back from
some switching activity)" and so on.
Clock-in-a-can is meant to solve a lot of that.
LaTeX Commands Quick-Menu:
