I want to instantiate (port map) a component within a process but it seems that it is not allowed. Simply, the component
gets two integers and sends two outputs and I want to feed array elements to that.
for i in 0 to 7 loop
u1: myComponent port map( a(i), a(i+1), a(i), a(i+1));
end loop;
Instantiate the component outside of a process.
Instatiating a component in a process makes no sense, as that would be like adding a removing chips from a circuit board while it is running.
architecture behav of switch is
component cross port( x, y: in integer range 0 to 31;
s, b: out integer range 0 to 31);
end component;
signal tmp1, tmp2: int_array;
begin
tmp1 <= ip;
gen_var:
for i in 0 to 6 generate
u1: cross port map( tmp1(i), tmp1(i+1), tmp2(i), tmp2(i+1) );
end generate gen_var;
ot <= tmp2;
end;
I have to say that int_array is an array of integer which is defined as
type int_array is array (0 to 7) of integer range 0 to 31;
But I get this error Signal "s" has multiple sources but is not resolved. How can I fix that?
