floppy32
Member level 2
Hello,
For some reason after a supply change I need to use this 12V relay with 19VDC.
I cannot find a 19V or even 18V version of this relay, so seems I'm stuck with using the 12VDC relay with 19V supply.
Somehow I need to match the coil voltage down to 12V form 19V.
In this case, would using a series 160 Ohm 1W resistor be fine?
