Users opinions on Magma tool
kumar_eee
Advanced Member level 3
Bangalore,India
Magma - Suggestions
Hi all,
I am doing my PG - Diploma in VLSI Design... Here I am having the Magma tool... Is it very important?...
Suggestions plz...
Magma - Suggestions
dude.. magma is a very good tool which works right from RTL to GDSII.. jes study the magma design flow.. its a full timing tool which attains timing closure..am not all that sure abt the closeness of timing closure.. but jes google it for the dsesign flow..
btw which univ are u from..
with regards,
arun
Re: Magma - Suggestions
Its very good if you are knowledgeble in Magma flow.Lot of companies use Magma in
their design flow.
perticularly for backend its really a good tool.
Magama is a very good toolto do your place and route......especially if your design is small then magma can speed up lot of things with little effort and finally u need only signoff runs of calibre and primetime to attain closure... it is easy to master with much of self explainatory commands...even hunch works well with it....
gud luck
Magma - Suggestions
magma u can learn tools and commands within 2 days.
new user to physical design can understand full flow thoroughly in short span.
my best idea if u wanna sign-off ur design short time then u can proceeed magma.
No sure whether you guys do have the tapeout experience with magma or not when you say something like that. Indeed Magma is a good tool, but in order to professionally handle it, it will long time.
Magma - Suggestions
cdic to be frank with you.. ive not worked in magma.. but our univ guys have worked with magma and they have designed a GSM chip which they managed to tapeout in some foundry in taiwan..BUT the question of professionalism does linger in everyones mind..
anyways share your experience
with regards,
arun
