Use of SPI pin as a GPIO
vhn
Member level 4
I'm using SPI interface for communicating with an external ADC. I've configured the inbuilt engine to operate at a specific speed. So the three lines (MOSI, MISO and SCLK) will be controlled by the microcontroller engine. Now, in order to find out whether conversion is over or not, I 've to poll the MISO pin.
But is it possible for a port pin already configured as an SPIO engine pin, to be polled as if it is a simple GPIO?
I'm using a ARM-7 based microcontroller which has different functionalities multiplexed. So we need to choose the behaviour of each pin using PINSEL registers. Whether I need to explicitly change functionality of these pins or can I simply poll this port pin?
Thanks in advance
Hi, when i've used tms470 arm7 with chipcon spi modules, i've polled MISO pin after every CS start being active (requerement for chipcon module) so i simple poll GPIO when SPI was configured in hardware spi mode
